Ana içeriğe geç
Beşinci nesil Sony PlayStation 5 DualSense oyun kolu için onarım kılavuzları, sökme işlemleri ve sorun giderme bilgileri. CFI-ZCT1W model numarası ve BDM-050 anakart modeli ile tanımlanır.
Replacing haptic feedback rumble motors?
I've noticed recently after playing a lot of the f1 game, my haptic feedback is just suddenly extremely weak compared to what it used to be. I've tried pretty much everything I think and nothing works, tried enabling the speaker in my sound settings but my controller doesn't even appear in there. I downloaded dualsense x and tested the right side and left side rumble motors by themselves and the right side is significantly weaker. Wanted to know if replacing the rumble motors would be possible on the V5 since I don't already see any guides here and if so is it just the rumble motors that need to be replaced or anything also involving the triggers?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hi!
The process is nearly the same as V2, V1 ect ect.
So you should be able to use the same guide that is created for the V2 or V1.
How is the haptic feedback? Still good? If yes, then you do not need to replace them, but just the rumble motor it self.
Guide: DualSense Controller v2 Vibration Motor Replacement - iFixit Repair Guide
If the haptic feedback buttons are back or got a lot weaker, then I advise to replace them as well.
Guide: DualSense Controller v2 Adaptive Trigger Replacement - iFixit Repair Guide
So far it does look like you just need to replace the rumble motors.
Please let us know if you have any questions!
DualSense Controller v2 Adaptif Tetikler Görseli
Kılavuz
DualSense Kontrolcü v2 Adaptif Tetik Değişimi
Zorluk:
Orta
30 minutes - 1 hour
DualSense Controller v2 Titreşim Motorları Görseli
Kılavuz
DualSense Kontrolcü v2 Titreşim Motoru Değişimi
Zorluk:
Zor
1 - 2 hours
Bu yanıt yardımcı oldu mu?
Puan 1
1 Yorum:
Not muting your mic can override your haptics settings and set them to low or off make sure the button at the bottom is lit orange.
tarafından
Yorum Ekle
Yanıtını ekle
brending sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 45
Her zaman: 806
