Ana içeriğe geç
PS5 DualSense Controller Triangle Button Stopped Working
Hi,
My son dropped my controller a few times and all of a sudden the triangle is not working very well. Sometimes it works, sometimes it doesn't. I tried cleaning it up from the outside and I'm a bit sceptical about opening it as I might just make it stop working completely. Does anyone have experienced something like that? R2 trigger is also in the same condition (sometimes it works, sometimes it doesn't).
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hi there!
Can you still press them in? How does the button feel? Still "Clickable"?
If not, you might want to clean everything inside (with isopropyl alcohol) and replace the rubber.
Guide: Sony DualSense Controller Buttons Replacement - iFixit Repair Guide (till step 33).
If that doesn't work, then you need to replace the button circuit membrane... There is no guide for it, yet. But you can follow the same guide to get there.
Regarding the R2, try cleaning first! If that doesn't work, then you might want to replace the trigger assembly..
Guide: Sony DualSense Controller Trigger Assembly Replacement - iFixit Repair Guide
Please let us know what worked or not!
DualSense Tetik Mekanizması Görseli
Kılavuz
Sony DualSense Kontrolcü Tetik Mekanizması Değişimi
Zorluk:
Orta
1 - 2 hours
DualSense Tuşlar Görseli
Kılavuz
Sony DualSense Oyun Kolu Tuş Değişimi
Zorluk:
Orta
1 - 2 hours
Bu yanıt yardımcı oldu mu?
Puan 2
2 Yorum:
Hello! Yes, I can still press the button and sometimes it works but for some reason it just stops working now and then.
I will try with your first option and write here if that actually worked or not. Thanks for the tip. Hopefully I won't break it :')
tarafından
Alright, yes then cleaning would be the first thing to do! Hopefully the controller will remain intact. Good luck with the repair :)!
tarafından
Yorum Ekle
Yanıtını ekle
Ricardo MVG sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 24
Son 30 gün: 120
Her zaman: 955
