Ana içeriğe geç
Error code 5C not draining
Having a nightmare with my samsung washer, I have had the code 5C and 5UD.
Lint filter is clear
Waste hose is clear with no kinks
Drain pump replaced
Hoses from drum to pump clear
Water level sensor clear but not replaced.
Any ideas
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Since you’ve already replaced the drain pump and confirmed that the filter, waste hose and tub-to-pump hoses are clear, I’d check one thing before replacing anything else: does the washer actually empty the water when 5C appears?
If water remains in the drum, I’d look at the pump wiring and whether the pump is actually being driven during the drain stage. If the tub drains normally but the machine still reports 5C, the water-level sensing side becomes much more interesting, including its hose and electrical connection.
Samsung also uses 5E, 5C, SC and nd for the same general no-drain fault family on different models. I put the diagnostic order together here:
https://www.errasift.com/samsung-washing...
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Kyle Dunford sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 20
Her zaman: 213
