Ana içeriğe geç
Logitech Signature M650 left click not working
Why is the left click on my Logitech Signature M650 mouse not working properly? I have to press it harder than usual or force click for it to register. What could be causing this, and how can I fix it?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 2
1 Yorum
Had same issue, disassembled and got some WD40 into the switch button works for me.
tarafından
Yorum Ekle
3 Cevap
Filtre ölçütü:
En Yararlı Yanıt
The switch failed. You can find the part on Amazon or AliEx. Search for phrases like:
Silent Mouse Button Switch 6*6*7.3MM Square Microswitch Two Pin
The switch is 7.3mm tall, and 6mm (or 6.2mm) square. You will need a solder sucker or wick, and to remove the board from the shell (4 screws and carefully pry out the battery contacts). The switch is held on by its own 2 pins and is easy to remove.
Resim
Update (11/16/25)
Getting in to the mouse is pretty easy. Start with these two screws inside the battery door. Then gently separate the mouse from the back. There is a clip near the front so you have to kind of slide the bottom forward to release it.
Resim
Resim
Remove the main cable
Resim
Remove 4 screws for the PCB & scroll wheel (scroll wheel comes off separately)
Resim
Remove the battery terminals by gently pulling up the whole PCB. Don't bend or stress the battery wires.
Resim
Use a solder-sucker to remove and then resolder with new switches for the left and right mouse button. .
Resim
Bu yanıt yardımcı oldu mu?
Puan 3
1 Yorum:
Instead of replacement with non-stock ones, a semi-permanent fix may be to simply exchange the right and left switches (assuming that the left one has worn out way quicker).
tarafından
Yorum Ekle
Yup, same problem. Disassembled it. Tried to directly press the button underneath slightly, which is just right for my use - doesn't register. Have to press it harder. The disassembly process is just like M550 (on Youtube), but be careful of the extra twisted wire for LED on the top shell on the M650.
So far, finding the switch for the 'SW1' has been unfruitful. Will update if I find anything.
Puan 1
1 Yorum:
There are many on Amazon or AliEx. Search for phrases like:
tarafından
Yorum Ekle
Resim
Resim
Thanks for providing the switch specifications! Successfully replaced both switches on my Logitech M650. The disassembly is straightforward and easy. I boght the switches from china, via Shoppee in the Philippines. The left button now registers light clicks perfectly instead of needing heavy force to actuate.
Puan 1
1 Yorum:
That's great news! thanks for sharing.
tarafından
Yorum Ekle
Yanıtını ekle
Horenus Dessalegn sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 10
Son 7 gün: 75
Son 30 gün: 363
Her zaman: 3,059
