Ana içeriğe geç
Taşınabilir Güç İstasyonu ve Akıllı Lehim Havyesi kombinasyonu olan FixHub Power Series | Taşınabilir Lehimleme İstasyonu için onarım ve sorun giderme bilgileri. Ekim 2024'te piyasaya sürülmüştür.
Idle mode during soldering
  • Firmware 1.4.2, iron solder enters into idle mode during soldering. idle mode is configured with 20 seconds large enough normally. I don't do a lot of movements when I solder but it seems that it's not enough.
  • Is there a way to have the iron solder more sensible? Else I can turn off idle mode and just power off the iron.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
1 Yorum:
I’ve forwarded you question to the iFixit team, hang tight!
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
@jonathanra66195 , You’re right, the motion sensor can sometimes go idle a bit too quickly during steady or delicate soldering work. Unfortunately, there isn’t currently a way to make the motion detection more sensitive.
The easiest workaround is to turn off Idle Mode entirely so the iron stays on until you power it down manually. Here’s how to do that:
  1. On the iron, open the Settings menu.
  2. Scroll down to Idle Enable.
  3. Toggle it Off.
  4. Optionally, set your Sleep Timer or Auto Power Off for safety.
That’ll keep the iron active the whole time you’re working. Just remember to switch it off when you’re done — disabling Idle Mode means it’ll keep drawing power and can shorten tip life a little over time.
Let me know if this helps or if you have any other questions.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
jonathan ramos sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 16
Her zaman: 207
