Ana içeriğe geç
Released in 2010, the Flip Mino HD is a pocket-sized camcorder with 4 GB and one hour of shooting capacity.
Where to buy replacement batteries for flip minoHD
Hello I have a couple of flip mino hds that i have taken apart and I have tested all the batteries and they are all dead. When I attach a working battery from different mino it works fine! Anyone know where I can find replacement parts?
I have tried batteries plus and called flip. batteries plus could not find a replacement and flip told me they do not sell replacement batteries for the mino as it is an internal battery.
Please if anyone has any advice it would be greatly appreciated!
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
3 Yorum
It might be possible to replace the battery, but to keep the case and circuit board. Do you have a part number on your battery?
tarafından
Yorum Ekle
7 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hi,
I've found a source of the battery (only large quantities from this supplier). Does anyone know how the PCB controller attached to the Flip Mino battery might be reused? The original is spot welded.
I'll bet there are lots of these cameras out there that could be saved if we could figure out how to safely install just a new battery in this recorder.
Here are the data on the battery and it's supplier:
Lithium ion Sanyo 553450 UF553450Z battery cell
Part Number: 0204-0019-00
Model Number: 1UF553450-1-T0423
http://www.alibaba.com/product-gs/349657...
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Part:http://www.amazon.com/Flip-Video-Ultra-R...
Best of Luck,
Puan 0
3 Yorum:
Thanks but this is not the battery for the minoHD.
Does anyone know if it is possible to buy a regular li-ion 3.7 v 1150mAh battery and install the board from the old pack onto it?
tarafından
Unfortunately, that was the only battery on the market. Unless you buy a used or broken one, and transfer the battery, there is no other way to do so.
Best of Luck,
Tough Gaming Technical Support
Agent Elisha
tarafından
Battery for Palm One LifeDrive Pocket PC seems to be an equivalent but connector needs to have four leads. Have ordered one and if it is a replacement will report.
tarafından
Yorum Ekle
Any more recent news on battery replacement for a MinoHD? Ours no longer keeps a charge for more than a few minutes.
Puan 0
1 Yorum:
EBAY has the internal batteries for the flip
tarafından
Yorum Ekle
I have purchased many of these batteries here http://bestbattery.biz/Cisco/221946-F460...
Puan 0
Yorum Ekle
How do you open minoHD for changing the battery?
Puan 0
Yorum Ekle
If you need cheap and high quality durable camcorder batteries then cheak this http://broadcastbatteries.tv/
Puan 0
Yorum Ekle
This is a direct replacement battery, with the same 4 wire connector!
https://www.amazon.com/gp/aw/d/B00ET08ZK...
Puan 0
Yorum Ekle
Yanıtını ekle
ecarter1117 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 10
Her zaman: 8,032
