I need this cable
Bu iyi bir soru mu?
Yes the sensor cable needs to be connected and working. Apple in this series requires the sensor to be calibrated if you change it. Also note a new part will not have the sensors firmware downloaded to it yet so that will require access to Apple's paywall tool by buying the part directly from them (see the lower answer segment)
Getting a used part is the cheaper way and the magnets frame on the lids side can be rotated you should be able to dial in the adjustment by carefully rotating the magnet so the sensor already programmed setting is reused. With the newest macOS you can also review your parts and by pass Apples serialization as they caved on it. Sadly many used parts houses only have the new part presently which depending on your OS level maybe an issue. I haven't tried the onboard recalibration process yet on this series so I can't tell you if it works or not.
Here's the details on the needed part: Lid Angle Sensor 661-23648
To get the part directly from Apple from their Self Service site Apple self-service Repair just go to the #2 option to order it and the Apple official repair manual is here 16" MacBook Pro (2021) repair manual
Bu yanıt yardımcı oldu mu?
Thank you for the info! I am going to try the used method. F Apple!
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 38
Her zaman: 298
2 Yorum
That is the lid angle sensor cable. What is your exact model (year) as there are a few different versions.
DanJ tarafından Paylaş
Hi and thanks for responding, it is a 2021/2022
Model: A2485 EMC: 3651
Would this cause the keyboard to not work?
Corey Hardenburg tarafından Paylaş
