Ana içeriğe geç
20 Eylül'de piyasaya sürülen Apple'ın 2019 yılı ana akım iPhone modeli; 6,1 inç LCD dokunmatik ekran, çift kamera ve altı farklı renk seçeneğiyle geliyor. iPhone XR'ın devamı niteliğindedir.
How to hard reset iPhone 11
how to hard reset iphone 11
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
1 Yorum:
how to flash iphone 11
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
Hello.This operation will not erase the data.
The procedure is as follows.
Press the volume up button and release it immediately.
Press the volume down button and release it immediately.
Press and hold the side button (power button).
When the Apple logo (apple mark) appears, release your finger.
Matters to be attended to
This procedure is intended to troubleshoot if a normal restart is not possible or if the screen freezes.
If "hard reset" means "initialization" to return the iPhone to its factory state, the operation method is different. After initialization, all content and settings in the iPhone will be erased. If you want to initialize, you need to do it from the "Settings" app or connect it to your computer (Finder or iTunes).
This is the end. From gkps.
Bu yanıt yardımcı oldu mu?
Puan 0
1 Yorum:
Light up the flashlight from the control center
Open Control Center: For iPhone 11, tap the upper right corner of the screen and swipe down.
Tap the flashlight icon: Tap the flashlight icon to turn on the light.
Turn off the light: Tap the icon again to turn off the light.
"Turn on" the flash with the camera app
Launch the camera app: Open the "Camera" app from the home screen.
Tap the flash setting icon: Tap the lightning mark displayed at the top left of the screen.
Select "On": Select "On" from "Auto", "On" and "Off".
Setting to light up the flash when receiving incoming calls or notifications
Open Settings: Open Settings and select Accessibility.
Tap "Audio and Visual": Select the "Audio and Visual" item.
Turn on "LED Flash Notification": Turn on "LED Flash Notification".
Set to muting: Turn on/off "Flashing at muting" if necessary.
From gkps.
tarafından
Yorum Ekle
Reset your iphone
Puan 0
Yorum Ekle
Yanıtını ekle
Oguta Sokya sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 8
Son 7 gün: 70
Son 30 gün: 231
Her zaman: 1,511
