Ana içeriğe geç
Orijinal Nokia 8110'un yeniden üretimi olan bu telefon 2018 yılında piyasaya sürülmüştür ve Matrix Telefonu olarak da bilinir.
How to update firmware for US use.
My phone was purchased on line. when arrived found out not intended for USA use. Was set up for Vietnam. Changed language in settings but never got good or full support from ATT. Now have Cricket. Would love to start using that great phone again. Can the firmware be changed to something modern and USA/ Cricket supported? Can the battery be replaced.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
You can find the battery on Amazon and other places and videos on YouTube for how to do it.
I just spent some time trying to find an answer for you, at first all I found indicated it's probably not an update-able issue, rather the fact that the US carriers no longer support the bands in use by the phone. More digging however led to the conclusion that it still can I found this. It seems to say a number of carriers DO still support the phone.
So, the usual route to make such a phone usable in the US (if necessary) would be to flash the manufacturer's stock ROM for the particular carrier if available, in this case probably AT&T where you could, if they sell the phone, get the appropriate ROM to download. Or from Nokia a stock version for the exact model you have as well as in US English. On XDA and other places I found that yes, there are actually several options to upgrade your OS, should you wish to do so, KaiOS, Android and a couple others. I'd check with your carrier first and see if they have a ROM for the phone and that, yes, whatever you plan to do, will work. Flashing a new OS is not risk-free though so the ball is in your court. It may work as is with a new battery, or you might want to stick a newer or preferred OS in the puppy, I've done that several times and won't discourage you, just be careful, understand every action and have everything you need before you begin... You CAN brick it if something goes wrong.
Good Luck.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
It sounds like you're encountering a firmware-update barrier with your setup. A good first step is to check compatibility ensure your device’s region (US in your case) and version matches the firmware you’re trying to install. Next, back up any critical data before proceeding, since firmware updates can erase or corrupt data if interrupted. Also, make sure your network connection is stable and you’re using the correct USB or interface cable (a bad connection often causes failure).
Puan 0
Yorum Ekle
Yanıtını ekle
John Fagan sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 19
Her zaman: 236
