How do you fix this error
Bu iyi bir soru mu?
“Hard drive not installed” on a Dell Latitude usually means a loose or faulty SATA/SSD connection. Reseat the drive, check the flex cable, ensure it’s in the correct slot, and run Dell Diagnostics (F12). Update BIOS and try another drive if needed. Often the issue is a failing SSD or connector.
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 28
Her zaman: 203
