Ana içeriğe geç
Valve tarafından üretilen popüler el tipi oyun konsolunun 2023 yılında yenilenen sürümü olan Steam Deck OLED için onarım, söküm ve sorun giderme bilgileri. 16 Kasım 2023 tarihinde piyasaya sürülmüştür. 1030 model numarasıyla tanımlanır.
Steam deck Battery Health
When I got my Steam deck about a year ago, I would get 8-9 hours in half life 2 and 2.5 hours in cyberpunk 2077, now I get around 6.5-7 hours in half life 2, and 2 hours in cyberpunk, should I replace my battery soon, or wait a bit to replace it, the system still says its at 100% percent health but I don't believe that number entirely.
Bu iyi bir soru mu?
Puan 0
2 Yorum
could be dried thermal paste causing the CPU temperature to rise and requiring higher fan rpm to cool the console, drawing more power and decreasing battery life. Does your Steam deck feel hot when gaming?
tarafından
Not really, if sits around 65-70 degrees when playing a really heavy game like cyberpunk
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
You probably shouldn't replace your battery right now. All battery age, but if there's only about an hour's difference in battery life compared to when it's new, replacing the battery now would be a waste. A new battery's both expensive and pretty hard to replace if it's your first time fixing stuff. If it works, it works. Wait until the battery life's significantly short or when it starts to bother you a lot, then replace it.
However, if you're really paranoid about battery life or feel like you'd like a few more minutes of cyberpunk, here's the guide.
Steam Deck OLED Battery Replacement
A lot of glue and fragile cables, so make sure you follow the steps carefully. It would be a good idea to read the guide before you actually start to replace it, to get a general idea of the steps.
Bu yanıt yardımcı oldu mu?
Puan 0
1 Yorum:
That's what I thought as well, I've repaired adhesive batteries before, but I agree that I should probably wait to replace it.
tarafından
Yorum Ekle
Yanıtını ekle
Caleb sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 7
Son 7 gün: 52
Son 30 gün: 235
Her zaman: 3,100
