Ana içeriğe geç
Apple AirPods (3. Nesil) kablosuz kulaklıklar için onarım ve söküm bilgileri.
Sound loss on one side
For example, the right side operates loudly and the left side operates quietly.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
If you can hear through it the sound duct is clogged with junk! Just dampen a Cotton Q-Tip with some isopropyl alcohol (not wet!) and carefully clean in stages the duct port, you should not need to enter, if you do you do risk pushing the junk into the sound chamber.
Here's a guide someone wrote up AirPods 3 Derinlemesine Nasıl Temizlenir (yalnızca kulaklıklar) scraping off the big stuff makes sense. Mine don't have any screen unlike these.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
The single-side quietness on AirPods 3 almost always comes down to one of three things: (1) the sound duct/mesh on the quiet bud is clogged with earwax or dust — the cleaning answer above is the right first step; (2) the balance slider got bumped — check Settings > Accessibility > Audio/Visual and make sure Balance is centered; (3) a degraded ear-tip seal. Quick test: swap the tips between buds — if the quietness moves with the tip, it's fit, not the driver. If cleaning plus balance doesn't bring the left side back, these AirPods quiet fixes (https://fixmyphonespeaker.com/blog/why-a...) walk through the remaining checks (mono test tracks, reset procedure, when it's actually a dead driver). (Disclosure: I help build FixMyPhoneSpeaker.)
Puan 0
Yorum Ekle
Yanıtını ekle
Soufiane sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 7
Son 7 gün: 19
Son 30 gün: 59
Her zaman: 230
