Ana içeriğe geç
Apple's line of laptops for professional and power users. To date, the MacBook Pro line includes 13, 14, 15, 16, and 17-inch variants, with major revisions defined by Pre-unibody(Original), unibody, Retina display, Touch Bar, and SOC (system-on-a-chip) designs.
MacBook Pro 14" replace speaker without disconnecting the battery
Macbook Pro 14" M3 Max left speaker is crackling. I saw in the guide that I have to disconnect trackpad cable and battery cabels etc, so basically the disconnect battery before replacing the speaker.
Can I replace it without disconnecting it? I always use non metalic tools to disconnect cables, so I'm not afraid about shorting something on the logic board during the process(I assume thats why it should be disconnected).
Is there any other reason beside that? I don't want to spend more time on disconnecting it than replacing the speaker if I don't have to :D
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Simple answer - NO!
So you have a loaded gun, would you hand it over to your fourteen year old? Of course not! He may not have the skills on proper handing of the gun.
Why risk the damage you might cause? It doesn't take much to damage things and the damage could be a much more expensive repair!
So back to guns... of course you would remove the magazine and make sure the chamber was also cleared before handing over your gun to your kid. You also use a gun safe to hold it when you didn't have it on your person, as you are ultra careful! As you know kids don't comprehend the dangers of gun. Either hurting you or someone else in your family and that hurt might be permanent.
Shortcuts = Risk
Bu yanıt yardımcı oldu mu?
Puan 1
1 Yorum:
Thanks! Then I take my time and will do it properly :)
tarafından
Yorum Ekle
Yanıtını ekle
steve83 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 18
Her zaman: 18
