Light control are jammed
Cannot turn on the light the controls had jammed
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Your Grand i10’s light control is likely stuck because of a failed or worn combination switch, though it could also be a blown fuse or a dirty switch mechanism. Try gentle movement + contact cleaner and check the headlamp fuse. If it’s still jammed, the stalk assembly needs replacement — a quick and inexpensive repair at most workshops.
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 30
Her zaman: 181
