Ana içeriğe geç
Olympus OM-D E-M10 Mark II, 2015 yılında piyasaya sürülen 16 megapiksellik aynasız bir fotoğraf makinesidir. Bu fotoğraf makinesi, profesyonel özelliklerden ödün vermeden amatör fotoğrafçılar için uygun fiyatlı ve kullanıcı dostu olan, kullanımı kolay platformuyla lens değiştirebilir.
Warning about internal temp to high
Hi! I have this camera and as soon as I turn it on I get error that the internal temp is to high and it turns off. I have tried updating to latest firmware via SD-card and that worked. I also bought another battery to see if that helps. It seems that the internal temp sensor is broken or something. Is there a method to "reset" internal temp sensor? Has anyone disassembled the camera and know if it is hard to reach the sensor to look at? What would the next step be?
Oh, I also tried putting the camera in the freezer for maybe 30 mins but I instantly get the high temp warning even after that
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Well I doubt resetting will solve your issue, the alarm it trying to tell you there's a problem something is overheating! Did you get the camera wet or bang/drop it?
Bu yanıt yardımcı oldu mu?
Puan 0
2 Yorum:
The camera looks to be in perfect condition and i don't think there had been water. The problem is i have tested to put it in the freezer for 30 min but it warns of heat instantly antway
tarafından
@patrikradacic - it's possible a sensor has failed. But it's not wise to put cameras into freezers! In the warmer chilled section yes but only when placed is a plastic bag with as much air removed! As you don't want condensation to collect inside!
tarafından
Yorum Ekle
Yanıtını ekle
Patrik Radacic sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 13
Son 30 gün: 38
Her zaman: 309
