Ana içeriğe geç
Kasım 2019'da piyasaya sürülen MacBook Pro 16'' için onarım rehberleri ve sökme bilgileri. Model A2141, EMC 3347.
Stuck in DFU mode
Laptop had water damage on elc180 that powers nand chips, after repair laptop is stuck in DFU mode and revive option gives error amrestoreerrordomain – 0x6 (6)
Data is the most important part of the repair if i do a restore and delete data from laptop repair is not of anny help.
does someone have a solution that saves data.
All voltages and resistances are fine laptop is only not turning on vcore on cpu and gpu.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
The low level aspects of the Flash chips (NAND) are corrupted. Without a DFU restore you really can't get past to save the data, sorry.
As a Hail Mary see if an external drive which is setup as a bootable drive will at least let you boot up. While you likely won't see the internal drives data as it's encrypted by the user account can you even get that far?
Bu yanıt yardımcı oldu mu?
Puan 0
2 Yorum:
Hi, do you by anny chance have T2 rom files for A2141 820-01700-05
tarafından
@dimitrijes46692 - The T2 chip is not reprogrammable! It is a gate array chip with a burnable Readable only ROM. The systems firmware is held in a EROM chip, but that won't help you here. That nukes the access to the NAND's like rebuilding via DFU.
tarafından
Yorum Ekle
Yanıtını ekle
Dimitrije Stefanovic sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 24
Her zaman: 531
