Ana içeriğe geç
laptop keys are not working
LAPTOP KEYS ARE NOT WORKING
How to rectify
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
5 Yorum:
@yathishs what is the complete model number for your laptop? What have you checked? What have you tried? Does it work with a USB keyboard? What OS are you using?
tarafından
My keyboard space bar is faulty.
It hardly creates spaces
tarafından
Have you done anything that could have damaged it lately? Such as dropping it, jostling it, or even slamming it shut. Is the key 'stuck' (hard to press down), or does it press normally. Are some areas easier to press down than others? Does it make a clicking noise after you press the key (sounds like plastic breaking, not referring to the normal key noise)? Like the comment above, what laptop are you using? How long has this been going on? There isn't really an answer because you lack information. To unstick a key, you can try condensed air to blow out any debris, or rub isopropyl alcohol to clean around the area.
It could also be a matter of the inside mechanism breaking, shifting, or sticking. This can lead to unresponsiveness, or 'stuck' keys that won't press down and can't be fixed with the aforementioned methods. This can sometimes go away with time, and you can sometimes find a sweet spot, but it can require taking apart the laptop and fixing the inner issue.
tarafından
The keys stopped working the likes of R and 4 5 6 and two more
tarafından
@ocheblaize what is the complete model number for your laptop? What have you checked? What have you tried? Does it work with a USB keyboard? What OS are you using?
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
check software is up to date....
downloads and install keyboard tester software from any website its free .after install check (press ) with every signal keys .....
if not showing green color when press the every ky .need to replace the keyboard
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Yathish S sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 18
Her zaman: 233
