Ana içeriğe geç
It fell in to water then it’s not turning on
How can i fix it
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
@coneyjamal43516 if the whole laptop fell into water, you will have to totally disassemble it. Then you will need to clean the logic board (and all other circuit boards) with high grade (90%+) isopropyl alcohol. If your laptop has a HDD you most likely will have to replace that since water might have gotten into the circuit bord etc. as well. Yes, you can try and use it but do not be surprised if it will not work.
Ultimately this is a big job that may or may not work again, but there is nothing wrong with trying. We will need to know the exact model for this laptop so we can be more specific about what needs to be done.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
coneyjamal@icloud.com sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 13
Son 30 gün: 13
Her zaman: 13
