Ana içeriğe geç
2.2 GHz (3.4 GHz'e kadar Turbo Boost), 2.5 GHz (3.7 GHz'e kadar Turbo Boost) veya 2.8 GHz (4.0 GHz'e kadar Turbo Boost) dört çekirdekli Intel Core i7 işlemci, 6 MB paylaşımlı L3 önbellek ve opsiyonel AMD Radeon R9 M370X harici grafik işlemci (dGPU).
Single Graphic Vs Dual Graphic Display Assembly
@danj I have a 2.8 GHz 2015 DG with a faulty display & have found a single graphic 2.8 GHz 2015 model with a good display for cheaper then a replacement Assembly with a 1TB SSD & a near new battery that has just 9 cycles for under $160! I cannot find any info to suggest there is any difference or compatibility issue in swapping over the complete display assembly's. @danj I think your extremely familiar with these as you use one yourself. Need confirmation before I take the plunge and purchase it.
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
They both use the same screen. It's easy to verify using TheBookYard listings as an example Parts for Apple MacBook Pro 15" Mid 2015
Bu yanıt yardımcı oldu mu?
Puan 1
5 Yorum:
Yes I thought they were the exact same also but just needed confirmation thanks.
tarafından
Out of curiosity what would make the AMD Graphic kick into action? IF gaming, playing a video, High resolution pictures, external display? I found this video https://www.youtube.com/watch?v=KtpZF22H...
tarafından
@livfe - The App requests it as the preferred option. This is part of the Apps code framework. There really isn't a need to alter the display setting from a user perspective. If that was needed that would be a crappy App to have not have the setting set, or someone coding an App who needed to see the difference.
tarafından
@danj Yes, I didn't play with anything from this video, just curious what causes it to switch from Intel to AMD.
tarafından
@livfe - Don't press the Red Button! 😂🤣😂🤣😂🤣
tarafından
Yorum Ekle
Yanıtını ekle
livfe sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 4
Son 30 gün: 15
Her zaman: 155
