Ana içeriğe geç
Model A1136 / 30, 60, or 80 GB hard drive / black or white plastic front
Select Button - Rubber contact pad slippage
I'm having recurring issues with the rubber contact pad underneath the center select button slipping. I've gotten pretty good at disassembling the iPod and re-centering the pad, but does anybody have any suggestions for an adhesive I could use to make a more permanent fix, as I've had to do it five times now?
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
Joe Seddon, if you are talking about the little black rubber pad that sits on top of the actual switch, I have previously glued mine with cheap rubber cement. I usually stay away from anything else like superglue etc. All it takes is a little dab of the glue, don't go overboard with gluing things together....:) Hope this helps, good luck.
Bu yanıt yardımcı oldu mu?
Puan 4
2 Yorum:
Rubber cement was my first impulse, but I wasn't sure enough to just try it. Since someone says they had good luck with it themselves, I'll give that a try!
tarafından
I do it on the once i fix quite often. Have not had a single issue with that. Good Luck.
tarafından
Yorum Ekle
I just found this answer and figured out that mine was off to the side and the cause of my center button issue. Just not sure where to put the light grey rubber square-U things that fell out though.
Puan 0
Yorum Ekle
Yanıtını ekle
Joe Seddon sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 6
Son 30 gün: 14
Her zaman: 715
