Ana içeriğe geç
28 Temmuz 2017'de piyasaya sürülen New Nintendo 2DS XL, 2DS el konsolunun teknolojik olarak geliştirilmiş bir modelidir. Nintendo DS serisinin dokuzuncu ve son yeniden tasarımı olan bu konsol, orijinal 2DS modelinden çok daha büyüktür ve güncellenmiş 'New 3DS' sistem serisinin tüm özelliklerini ekler; sadece üst ekranda stereoskopik 3D oyun oynama özelliği eksiktir.
problems with hinge/spine of 2ds?
so when i try to move the top screen of my new 2ds backwards after repairing and swapping the shell it doesnt close fully on the back and has trouble when i try to put the top screen flat in line with the bottom ive tried opening and cleaning it i also reseated the top lcd
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
This usually happens when the hinge isn’t aligned correctly after the shell swap. Even if the screen and LCD are re-seated, the top housing won’t close or sit flat if:
1. The hinge barrel isn’t fully rotated into its locked position.
It needs to “click” into place. If it’s off even a little, the lid will resist closing.
2. The ribbon cable has tension or is twisting inside the hinge tunnel.
A slight twist is enough to keep the top shell from lining up.
3. One of the hinge tabs isn’t sitting in the shell track.
The system will close on one side but not the other.
Quick fix:
Open the system back up, rotate the hinge fully until it locks, check that the ribbon sits smoothly with no sharp bends, and then reassemble.
No new parts needed unless the hinge barrel is cracked.
If you want, I can tell you exactly how to check alignment step-by-step.
Bu yanıt yardımcı oldu mu?
Puan 0
1 Yorum:
that would be nice thanks
tarafından
Yorum Ekle
Yanıtını ekle
God o sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 12
Son 30 gün: 56
Her zaman: 539
