Ana içeriğe geç
Green screen without any damage at all
For some reason one day my screen had a green line out of nowhere didn't took it that serious then some days later as I was using it 80% of the screen became green as well but u can still see it normally just that now it has a green tone
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
3 Yorum
@luisalejandro sounds like an issue with your LCD screen. Connect an external monitor and let us know if that displays correctly. If so, then the issue is most likely your LCD screen. Yes, this can happen from one minute to the next without any prior warning sign.
tarafından
@oldturkey03 I already plugged in an external monitor and no signs of the green it's also not just a block of green u can still see image on it still
tarafından
@luisalejandro Does the angle that the lid is open have any effect on the green tint? That would indicate a flex/cabling issue.
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
You'll want to determine if it's the display itself or your GPU that's at fault here. The easiest way to do that is to plug in an external monitor. If the monitor exhibits the same symptoms, your GPU is having issues; if not, you may need to replace the screen.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
Luis Alejandro sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 14
Her zaman: 172
