Ana içeriğe geç
Microsoft USB Force Feedback joystick oyun kumandası. Ağustos 1998 X05-92622
Auto Center Weak in One Direction
Recently picked one of these up used (only way to get them today, obviously), and the auto-centering function seems to work very weakly when I pushed the joystick forward, or not at all. I'm assuming there is some mechanism inside that needs to be cleaned/fixed/replaced. Has anyone done a teardown of this base, or repaired the Auto Centering/FFB mechanisms inside? I'm assuming most of the parts inside could be ordered and/or 3D printed, but I don't know where to start.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
@dantehchad take a look at this teardown You may have some bad pots that may need to be replaced as well as cleaning the gears, motors, etc. Also, try the ForceTest.exe from here or the one from here, and see if you can configure your joystick to give you a better auto center feel.
While you work on your Joystick, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has a device with the same issues as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Dan teh Chad sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 37
Her zaman: 260
