Ana içeriğe geç
iPhone 13 için tamir kılavuzları, el kitapları ve sorun giderme yardımı. iPhone 13 cihazınızı kendiniz tamir etmek için ihtiyacınız olan her şeyi edinin.
How to apply the Display Assembly Adhesive
I noticed that there are no instructions indicating how the adhesive should be applied. Is it pre-cut? Do I need any additional materials besides the adhesive itself? At what stage should it be applied?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
While you can use a liquid or gel-type glue, the pre-cut adhesive available here and elsewhere are recommended, as they are made to fit exactly on your phone and will provide a modicum of water resistance when applied properly.
If you read carefully on the iPhone 13 Screen Replacement guide, you'll find that Step 26 specifically mentions replacing the adhesive and gives a link to a page showing you how. Here's the adhesive page.
iPhone Display Adhesive Replacement - iFixit Repair Guide
You haven't mentioned what repair you're doing that requires you to remove the screen, but typically you'll install the adhesive just before you reconnect the display. Depending on the battery connector, you may need to plug it in as you install the adhesive so the backing sheet will lay flat on the phone as you press down the edges; if you do, be sure to unplug it again before proceeding to connect the screen.
If you haven't installed screen adhesive before, I might suggest you buy a couple of sheets of the precut adhesive. That stuff is not forgiving at all, so if it doesn't go on correctly the first time, you don't get a second chance; if you're like me you'll just end up with a tangled ball of glue. Having a spare on hand would mean you won't have to wait for a reorder to arrive before you can put your phone back together.
iPhone Display Adhesive Görseli
Kılavuz
Zorluk:
Orta
1 hour
iPhone 13 Ekran Görseli
Kılavuz
iPhone 13 Ekran Değişimi
Zorluk:
Orta
1 - 2 hours
Bu yanıt yardımcı oldu mu?
Puan 3
Yorum Ekle
There is an official guide from Apple, no need to reinvent the wheel here.
https://support.apple.com/en-us/100408
Puan 0
Yorum Ekle
Yanıtını ekle
Marco Baldassarri sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 44
Her zaman: 161
