Frigidaire dishwasher making nois
My dishwasher makes noise at the start of the wash cycle but not during the whole wash cycle . Still does a good job cleaning the dishes wondering if its the motor or the pump
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Sounds like it could be something small stuck around the pump area or maybe the circulation motor starting to wear a bit. I had a dishwasher do something similar where it would make a grinding noise for the first minute, and it ended up being debris down in the sump. Since yours is still washing dishes properly, I probably wouldn’t panic yet, but I’d check the filter and underneath the spray arm for any bits of glass or food buildup. Might be worth listening closely to see if it sounds more like a buzz, squeal, or grinding noise since that can usually point you in the right direction. Hope you get it figured out without needing any major repair.
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 28
Her zaman: 154
@rob58184 what exact model number is your dishwasher?
oldturkey03 tarafından
