Ana içeriğe geç
1.8GHz dual-core Intel Core i5 (Turbo Boost up to 2.8GHz) with 3MB shared L3 cache
Can I upgrade the ssd of the mba 2012
hi may i know for the latest mba2012 we can upgrade the 128gb ssd to 256 or 512 gb ssd ourselve? and how about the macbook pro retina 2012 for the same questions from 256gb to 512 gb ssd?
2. if yes then can u recommend what brand of ssd we should get and anything we need to take notice before we buy the ssd?
Thanks and best regards : )
Bu iyi bir soru mu?
Puan 2
Yorum Ekle
3 Cevap
Filtre ölçütü:
Seçilen Çözüm
Hey!
The MacBook Air and the MacBook Pro Retina both use custom connectors.
There have been fitting SSDs for older MacBook Airs around, but Apple changed the design of the connector with the 2012 model. You should also note that the SSDs of the MacBook Air and the MacBook Pro Retina are not interchangeable.
Chances are however good that there will be compatible drives for both machines in the coming months.
Long story short: Currently NO, in a few months PROBABLY YES.
Bu yanıt yardımcı oldu mu?
Puan 4
2 Yorum:
Thanks senthor for ur good info!!!
tarafından
Thanks, good info for me too.
tarafından
Yorum Ekle
OWC are now selling SSDs for the newest MBAs! Check out this link: http://eshop.macsales.com/shop/SSD/OWC/A....
If the link doesn't work, google OWC for more info. Hopefully, OWC can provide upgradeable SSDs for the MBPRs!!
Puan 4
Yorum Ekle
Its a REPLACEMENT drive. There are external adapters/housing to use the SSD module that you remove as an external drive (super fast one). Probably worth it for a 128GB SSD class usb 3.0 external disk that fits in your pocket. OWC also makes that adapter (part of a kit too).
Puan 0
Yorum Ekle
Yanıtını ekle
lsgan sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 18
Her zaman: 43,309
