Ana içeriğe geç
The iFixit Pro Tech Toolkit is the industry standard for precision electronics repair. Trusted by professionals and DIYers alike, it contains everything you need to tackle repairs on smartphones, laptops, gaming consoles, and more.
How to identify ip torx
Does my pro tech kit have ip torx how can I tell
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
1 Yorum:
FYI - IP Torx refers to Internal Plus (IP), a type of Torx Plus fastener and driver system designed for higher torque and reduced wear, featuring more rounded lobes than standard Torx, with tools labeled "IP" (e.g., IP20, IP27) for internal drive, making them distinct from regular Torx (TX) and External Plus (EP) drives, as they offer a larger contact area for demanding industrial applications.
tarafından
Yorum Ekle
3 Cevap
Filtre ölçütü:
The base kit doesn’t ship with them. You have to buy them separately. iFixit Precision 4 mm Screwdriver Bit
iFixit Precision 4 mm screwdriver bits. Replacement bits for the Pro Tech Toolkit, Mako Driver Kit, and Manta Driver Kit. Görseli
Ürün
$2.99
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
The IP Torx bits are only available within the larger sizes. So depending on your needs the standard bits will work in the smaller sizes without any problem.
Here's what I have for my car.
9 pc of Impact Torx Plus 6 point Socket Bit Set Kits: IP-20, IP-25, IP-30, IP-40, IP-45, IP-50, IP-55, IP-60, IP-70
Computers, phones and small appliances use the older Standard Torx.
Puan 0
Yorum Ekle
No, if you mean internal torx plus, the kit probably won't have it in it. I have the Manta kit, which has all the bits in the Mako and Mahi kits, and I believe the Pro Tech kit has the Mako in it. My kit has no internal torx bits, so I'd say your best option is to either use an internal hex or just find a drill and stick a screw in the chuck, although that could possibly damage the drill and/or the screw.
Puan -1
Yorum Ekle
Yanıtını ekle
lilacabyssguy sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 36
Son 7 gün: 36
Son 30 gün: 36
Her zaman: 36
