Sim card not working
I bought a used phone online and the sim card doesn't work. What can I do?
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Does it show "No Sim" even with the sim card inserted? If so the sim reader in the phone might be damaged. Sometimes it can just require bending the pins because they are not making contact with the sim card. Other times it will require replacing the sim reader if the pins are actually snapped. It could also be caused by other issues like the phone being blacklisted or a more serious issue on the motherboard.
Bu yanıt yardımcı oldu mu?
It says "no sim"
See if you can look inside where you insert the sim card for any damage. Could also be an issue with the sim tray.
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 28
Her zaman: 126
Have you tried placing a new SIM? You may have to go to a carrier to buy a new SIM card.
Please specify whether the SIM slot has a SIM card or not. :)
Bryan tarafından
@bryan56776
There are two sim card slots. None works. I have also tried a different card
Per Ivar Moen tarafından
@perivarmoen This could be an issue with the SIM card slot reader. I'm going to try and find the location of the SIM reader.
Have you tried doing a hard reset to your phone?
Bryan tarafından
I did the factory setting
