Ana içeriğe geç
Repair guides and support for cars and trucks by Ford Motor Company.
Hood sensor switch voltage
Hello.. I am trying to install a remote start kit in my grand daughters 2018 Ford Edge. It requires a working hood sensor circuit, I have discovered the voltage at the hood switch is 3 or 4 volts, Do I look for damaged wiring or could it be a bad BCM? Not sure how far into this I can go before I'm over my head.
Any thoughts please?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
@jerryparnell "Do I look for damaged wiring or could it be a bad BCM?" neither nor. "3 or 4 volts" That is actually the right voltage. It is a low voltage signal circuit coming from the BCM and that voltage is exactly what the BCM will provide. No error on this circuit.
The latch switch uses ground to indicate the hood is open. For a remote starter you most likely will need to find a wire that shows ground only when the hood is closed.
Bu yanıt yardımcı oldu mu?
Puan 3
1 Yorum:
Great.. I will look into this. Sounds like a logical solution,
Thank you
tarafından
Yorum Ekle
Yanıtını ekle
Jerry Parnell sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 17
Son 30 gün: 17
Her zaman: 17
