Ana içeriğe geç
Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2375 Soru Tümünü görüntüle
Is it possible to replace iPhone 4 camera with iPhone 4s's one?
Well, I have quite an old iphone 4, maybe 1,5 years old and first thing is that I don't like it's LED flash, in comparsion with newer models it's kind of yellow or even green, so all photos with it are comming with "greenery". So i thought I should find some camera module on Ebay (also, afraid to buy bad copy, don't even know how much should it cost). Second though was - is it even possible to change iPhone 4 and 4S cameras? Well, yes, I think there will be certain software problems (maybe not so critical?), but is it possible in hardware? Maybe you guys from iFixit would like to try it? =)
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
3 Cevap
Filtre ölçütü:
Seçilen Çözüm
No, the connector on the logic board is different.
Bu yanıt yardımcı oldu mu?
Puan 2
1 Yorum:
Thank you for fast answer, Scott =)
tarafından
Yorum Ekle
I have a similar question, is it possible to upgrade all of the internals (logic board, camera, etc) to the ones from the iphone 4s? is there anything inside the case of the 4 that is compatible with the 4s?
Puan 0
Yorum Ekle
The bottom mic and speaker unit can be swapped between iPhone 4 and 4S phones, you need to peel off the antenna cable from the speaker assembly because although the speaker/mic assembly is the same, the antenna cable isn't. But it's just attached with sticky tape. The 4 has short antenna, the 4S has longer antenna.
Puan 0
Yorum Ekle
Yanıtını ekle
mugi4ok sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 3
Her zaman: 3,000
