Ana içeriğe geç
RIDGID tarafından 2015 yılında üretilmiş 18V Lityum iyon 2 Hızlı matkap/vidalama makinesi.
How do I remove the chuck for replacement
I have removed the Phillips head screw, but all the instruction I find online, call for a torx head screw once the phillips head screw is removed. My model does not have that. is the chuck screwed on with internal threads or is it a press fit? Any help would be appreciated.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
You’ll want to open the chick all the way so you can see inside it. Once that’s done you can see what type of driver you need my dewalt uses Allen key. Now here’s the important part the threads are reversed turn right to loosen the chuck. And no you can’t use the drills own power to do that. You need to hold the base while you turn it.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Mike sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 24
Her zaman: 143
