Ana içeriğe geç
24 Eylül 2021'de piyasaya sürülen iPhone 13 mini, Apple'ın iPhone 13 modelinin daha küçük bir versiyonudur ve ikinci mini iPhone'dur. 5,4 inç OLED ekran, A15 Bionic işlemci ve çift arka kamera ile donatılmıştır.
Battery-only part-adhesive?
If I order battery for my iphone, just the part...does it come with adhesive? Or do I have to buy it separately?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Assuming you're talking about buying a battery from iFixit, the answer is stated under the Description heading in the right-hand column.
So yes, it does come with adhesive already installed on the battery; all you have to do is peel off the protective film and you're ready to install.
Protip: Be sure to plug in the battery connector before setting the battery in place, set the battery down and press it down, then unplug it again. Take it from me - and I learned this through experience - if you just set the battery in place, there's enough room for it to be placed such that the connector on the battery is out of reach of the socket on the motherboard. So don't be me, okay?
Replace the adhesive film that secures the battery to the rear case compatible with an iPhone 13 mini model A2481, A2626, A2628, A2629, or A2630. Görseli
Ürün
iPhone 13 mini Battery Adhesive Strips
Bu yanıt yardımcı oldu mu?
Puan 0
2 Yorum:
I see...to be accurate, I meant display adhesive.
tarafından Paylaş
@radekgomola Ah, then no, the precut adhesive for the screen is not included with the part only battery; you'll have to order that separately. Since the adhesive is the same price as the fix kit when ordered by itself, I'd say you might as well get the kit. Otherwise you can find it cheaper on places like eBay or AliExpress if needed, but not by much.
tarafından Paylaş
Yorum Ekle
Yanıtını ekle
Radek Gomola sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 52
Her zaman: 219
