5 blinks on CapsLock and Numlk
When Turn it own ... it shows black screen and 5 blinks....then shut off
what can I do here
Bu iyi bir soru mu?
what can I do here
Bu iyi bir soru mu?
@moradmorad86446 the 5 blink code usually means you have a motherboard failure. This can often be related to UEFI/BIOS corruption, memory errors, or a failed BIOS update. To try and fix that, perform a hard reset by disconnecting the AC adapter, hold the power button for 15-30 seconds, then reconnect and try powering on.
Anything different would mean you have to check your motherboard. For that, we will need to know the exact model of the board. It will be printed on the motherboard. Post a picture of yor motherboard with your Question. That way we can see what you see. Mevcut bir soruya görsel ekleme
To work on your computer use the HP ZBook Power G7 Maintenance And Service Guide
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 29
Her zaman: 163
