Pss5 not recognizing discs
Every time I turn on my PS5, the disc drive runs but says it does not recognize the disc. I have already tried replacing the disc driver laser, KEM-497aaa. The model is CFI-1115a.
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Hi!
Usually it is the laser, but it could be way more (drive board, other components on there, etc.).
I recommend to try with a new drive, and see what happens.
Note: Always transfer your original board (from the OLD drive to the >>> New drive)!!!
Can you let us know how that goes?
Thanks!
Bu yanıt yardımcı oldu mu?
I have already tried replacing the part 3 times that’s why I’m looking for any other ideas to try and help
Hi! Did you replaced the whole drive 3 times? Or just the laser? Thank you!
@dan0 I replace the whole drive!
okay, then I'm afraid it's related to either the motherboard or the PCB. Is there a way for you to test them (and do you have soldering experience)? If the PCB is broken, it would be difficult to fix as you cannot marry a new PCB to the motherboard. Otherwise I recommend to check with a local repair shop. Sorry.
Well, you can't re-pair the boards unless you happen to be Sony and have all of their proprietary pairing software. You might also try moving the component that actually pairs the drive PCB to the motherboard, but last I checked, that's not easy to do and requires microsoldering to pull off (But hey, try it if you want!). You could also try to figure out if there's a specific component on the board that's being problematic and replace it.
Son 24 Saat: 2
Son 7 gün: 10
Son 30 gün: 27
Her zaman: 103
