Ana içeriğe geç
Acer TravelMate X349, Acer tarafından üretilen bir iş dizüstü bilgisayarıdır. Bu sayfa, Acer TravelMate X349 ile ilgili onarım ve servis bilgilerini içerir.
How do I fix my mouse pad
So I was using the laptop normally until the mouse pad stopped working so how do I fix it?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
3 Cevap
Filtre ölçütü:
Hi, @ahmedayman93805 I gotchu.
I found the replacement mousepad here. Ask FixBot to assist you with replacement.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Well Check the "Magic" Function Key and also check for driver sometime outdated driver can also be the reason of this issue.
Puan 0
Yorum Ekle
If your laptop touchpad suddenly stopped working, start with simple checks. Make sure it isn’t accidentally disabled—many laptops have a function key (Fn + F-key) to toggle the touchpad. Restart your system, as it may be a temporary glitch. Go to Device Manager and check if the touchpad driver is missing or needs updating; reinstall it if necessary. Also check Settings > Touchpad to ensure it’s enabled. Disconnect any external mouse, as some systems disable the touchpad automatically. If none of this works, it could be a loose internal cable or hardware failure, requiring professional repair.
Puan 0
Yorum Ekle
Yanıtını ekle
ahmed ayman sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 23
Her zaman: 151
