Ana içeriğe geç
My vibration mode not working
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Check Vibration Settings
  • Go to Settings
  • Tap Sounds and vibration
  • Make sure Vibrate while ringing is turned ON
  • Tap Vibration intensity and increase it
Check Sound Mode
  • Press the Volume Down button
  • Make sure the phone is in Vibrate or Sound mode (not completely muted with vibration off)
Test Vibration Manually
  • Go to Settings > Sounds and vibration > Vibration intensity
  • Adjust the slider and see if the phone vibrates
If there is no vibration at all, continue below.
Restart Your Phone
Sometimes a simple restart fixes minor software issues.
Check Accessibility Settings
  • Go to Settings > Accessibility > Interaction and dexterity
  • Make sure no setting is disabling vibration
Boot in Safe Mode
This checks if any third-party app is causing the problem.
  • Press and hold Power button
  • Tap and hold Power off
  • Select Safe Mode
If vibration works in Safe Mode, an installed app is likely causing the issue.
Bu yanıt yardımcı oldu mu?
Puan 0
1 Yorum:
Not working I think vibration motor not working
tarafından
Yorum Ekle
Yanıtını ekle
Deb Mandal sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 29
Her zaman: 159
