Ana içeriğe geç
Engine check light is on?
Why is the Engine check light is on?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
My English might be unnatural, sorry.
1. Intake manifold variable mechanism (P2004) trouble
Failure where the intake manifold flap stays open
An actual case of P2004 occurred in a W203 C230
Intake efficiency gets disrupted → air-fuel mixture becomes rich → P2188 / P2190 may also appear simultaneously
2. Issues related to rich fuel (P2188 / P2190)
O2 sensor deterioration
Air intake leak (hose crack)
Mass air flow (MAF) sensor failure
In actual W203 cases, replacing the MAF improved the issue
3. Purge valve failure (common)
Valve that controls gasoline evaporative gases
In a W203 C180, the check engine light was caused by the purge valve
A part prone to failure considering the model year
4. Oil leak from cam magnet (cam actuator)
A common problem in W203 cars
Leaked oil travels along wiring and reaches the ECU → sensor malfunction
There are cases where oil reached the ECU via wiring, causing multiple errors
Needs prompt attention as leaving it untreated can worsen the problem
5. O2 sensor failure
Frequent in Mercedes in general
Causes poor fuel economy and unstable idling
Listed as a common issue in Mercedes vehicles
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
@jonvi90986 there are to many possibilities. Get the OBDII scanned and see what codes it will show. That way you know for sure what is going on with your MB. If you are somewhere in the USA, AutoZone etc. offers free scanning and it will definitely be a good start.
Puan 0
Yorum Ekle
Yanıtını ekle
Jon Vi sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 22
Her zaman: 158
