Can I replace the battery
can i replace battery
Bu iyi bir soru mu?
Hi, @paulmbaundegwa I gotchu.
I could not find a guide to replace the battery, but this is what FixBot said:
The Nokia C32 uses a 5000 mAh Li-Po battery with the model number WT510 [source|new_window=true]. While the official user guide lists the battery as non-removable, the device is designed for relatively easy disassembly [source|new_window=true].
Based on disassembly reports [source|new_window=true], the process is as follows:
Lithium-ion batteries can be dangerous if damaged. If your battery is swollen, do not apply heat. Ensure your battery is discharged below 25% before starting the repair to minimize the risk of a thermal event if accidentally punctured.
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 1
Son 7 gün: 16
Son 30 gün: 46
Her zaman: 383
