Why the air compressor not starting?
Why air compressor not starting
Bu iyi bir soru mu?
@innocentmutepfa start by checking fuse #28E which controls the compressor clutch relay. If your fuse is good, you will need to check the relay. Here is the Land Rover Discovery 4 HVAC Wiring diagram. Use that to check your compressors power lines.
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 29
Her zaman: 138
1 Yorum
@innocentmutepfa have you checked your fuses? What have you checked and tried already?
oldturkey03 tarafından
