Ana içeriğe geç
Mustang GT ve Mustang Cobra dahil olmak üzere dördüncü nesil Ford Mustang için onarım rehberleri ve destek.
Have low fuel pressure
Have changed fuel pressure sensors on fuel rail and on gas Tank .Have changed fuel pump .cranks after priming (turning key on and of 3 times ) and ideals if you press the accelerator like normally taking off it will die if you put it in gear and press the accelerator it will die if you slowly float the accelerator and park it will rev up all the way to 3500 RPMs but once you put it in here and mash the gas to go it stalls out. When you just crank it and let it sit there and Auto it autos for a while then it will all of a sudden start missing bogging down and die
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
1 Yorum
@martyleesmith what exact year and engine size is your Mustang?
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
I had a suburban that acted like this. Had me chasing ghosts thinking it was fuel. What fixed it for me? Oddly enough.... spark plugs. It would fall flat on its face unless i was in park. Then I could get the revs up a bit more. I replaced the fuel pump, filter, all that jazz. No difference. Then I replaced the plugs, and it immediately stopped all of that.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
Marty Lee Smith sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 10
Son 30 gün: 28
Her zaman: 144
