Ana içeriğe geç
Kasım 2019'da piyasaya sürülen 16" ekrana sahip MacBook Pro modelleri için onarım ve arıza teşhis bilgileri.
Slightly wonky key - M1 MacBook
My son picked the key off it still works and has some spring but is uneven
Does anyone know what part i might need to replace ?
Resim
Resim
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
4 Yorum:
Does any of the plastic on the key itself look broken/loose? If the clip-on area on the left side of the key is broken/bent, it may cause the issue you're describing. Also, make sure that there isn't anything stuck in between the key. Let me know if this helps at all.
tarafından
I think your right that the left side of the key cap is broken and its not attaching. I will try and replace and let you know if it works - thanks for taking the time to reply :)
tarafından
@albertmacstien Follow the video and remove the key cap and then try to reconnect it as the video shows, this would confirm if the key caps clips have broken away requiring a replacement.
tarafından
@albertmacstien No problem! It's my pleasure. Good luck repairing!
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
I hope this video can help How to replace arrow keycaps on a MacBook Pro A2141, A2251, A2289 and A2338 M1 & M2 (2019 - 2022)
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Here's a good source for replacement KeyCaps
Puan 0
Yorum Ekle
Yanıtını ekle
albertmacstien sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 21
Her zaman: 187
