Ana içeriğe geç
Kasım 2020'de piyasaya sürülen PS5 konsolu, büyük ölçüde geliştirilmiş görseller ve yenilikçi yeni bir DualSense oyun kolu sunuyor. Uzay çağına uygun siyah-beyaz renk düzeni, geçmişteki PlayStation tasarımlarından belirgin bir kopuşu temsil ediyor.
PS5 LAN Disconnecting/Reconnecting Repeatedly
I’ve been experiencing an issue with my PS5 where the LAN (Ethernet) connection repeatedly disconnects and reconnects almost instantly. This happens back to back , mostly within the first hour of turning on the console and starting a game. Sometimes it temporarily stops, but then the issue returns.
I’ve already ruled out the Ethernet cable by testing with another one, and I’ve seen others report similar issues online without a clear solution.
Side note: my HDMI port is loose, and I have to angle the cable for a stable display connection. I’m wondering if there could be any relation between the two issues maybe heat, board stress, or internal damage affecting both ports.
Would it make sense to replace the HDMI port first and see if that resolves the LAN issue, or is this more likely related to the Ethernet port or its solder connections?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
1 Yorum
I would bet its a heat-related situation. Especially if your console is fixed in the Vertical position, as this places the ether net port at the top edge - sitting directly above the ports where the internal fans vent excessive heat generated during gaming.
Had my PS5 since 2021, expanded my internal storage for an additional 2TB - and after 5 years, this bullshit starts happening? Conveniently enough, just in time for GTA6 to create enough hype that to cause a greed-driven inventory crisis (AGAIN !!!) for the 2nd time, since Covid - so the current scalp-rate has the cost of a PS5 Pro now fixed at the (currently) all-time-high price of $1,399 (a $100 increase from $1,299 - within the last 30 minutes...and apparently, this is the "last 1 available" - thanks, Amazon 🖕🖕🖕)
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hi!
First of all, I don’t think it’s related to each other, BUT I would fix it anyway.
You either need to replace the HDMI port or maybe you can solder it in again for good.
Replacing the LAN port is also recommended. I’m afraid it’s the port it self. I would fix it at the same time and see how that goes!
Be aware, both jobs are difficult… maybe asking a repair shop would be a good thing to do.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
Moose sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 20
Son 7 gün: 122
Son 30 gün: 437
Her zaman: 1,351
