Ana içeriğe geç
Üçüncü nesil Sony PlayStation 5 DualSense kontrolcü için onarım kılavuzları, söküm ve sorun giderme bilgileri. CFI-ZCT1W model numarası ve BDM-030 anakart modeli ile tanımlanır.
Faceplate Compatibility with other versions
Hi, I own a V3 Controller and it is the Spider-man 2 variant controller. It has developed stick drift and I am hoping to avoid having to solder anything.
Can I transfer the face plate and track pad plate onto a V5 controller?
If not, will the motherboard and sticks from a V5 fit and connect with internals from a V3?
For reference i have the motherboard serial number BDM-030. Any help is appreciated I would love to keep the livery on this controller if joystick replacement is the only option then that'll have to do. Thank you.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hi!
Yes that is possible, but you do need the EXACT same model. Also the motherboard must match with each other.
It could be a little difficult, if you buy a incorrect model it just won’t fit as it should be.
Also another option would be to bring to a local repair shop and ask them to solder new hall effect sticks in.
Please let me know how it goes :)
Bu yanıt yardımcı oldu mu?
Puan 2
2 Yorum:
Hi! Apologies for the late response I just attempted it, and it did indeed work. I bought a brand new dual sense and was able to transfer all of the internal components apart from the touchpad which I wanted to retain and the new battery housing. All the internals from a new controller bolt up perfectly. I wanted to reuse the touchpad and faceplate so I did. Due to small changes in architecture I had to also reuse the old battery housing, rear plate and trim piece.
tarafından
No problem at all! Glad that you got it solved :)! Thanks for sharing this with us! Have a great day!
tarafından
Yorum Ekle
Yanıtını ekle
Thorne sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 9
Son 30 gün: 25
Her zaman: 122
