Lack of power and whinning
After running my JD mower for about 10 minutes, there is a whinning and lack of power, especially going in reverse. After 30 min. not enough power to go up a small incline.
I have put on a new drive belt and sprayed it with a belt dressing. No change.
Bu iyi bir soru mu?
2 Yorum
First question is what model John Deere mower do you have?
Belt dressing is a lubricant that stops squeaky belts but unfortunately does nothing to help make the belt grip the pulleys better. In fact, quite the opposite.
If your mower has a hydro-static drive transaxle, then it might be low on fluid and is starting to slip. Once we know the model number, then we can look up some specifics.
BILL
HemiBill tarafından
HemiBill
Thanks for your response. I have a John Deere STX46 with a Hydrostatic drive. I have never added fluid to the transaxle in over 6 years.
Should I drain it and add new fluid? Is there a fluid filter? What type fluid should I buy?
Thanks
Tom
tom tarafından
