Ana içeriğe geç
The HTC Desire HD is an Android smartphone by HTC Corporation.
26 Soru Tümünü görüntüle
How to fix the volume buttons?
Hi to all, I need to fix the volume buttoms. Those that are on the left side of DHD. When I push over button - it works fine....but, on the contrary, the button + is hardly demage. I must push strongly and sometimes it doesn't work and sometimes it work. If I give an attention look to this volume buttons bar, I can notice that the volume button + is more inside the DHD than the other one.
So Can I fix it or Have I substitute the bar?
How could I do it?
Thanks in advance
MAx
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 2
Yorum Ekle
3 Cevap
Filtre ölçütü:
En Yararlı Yanıt
I had a similar issues with the volume button on my inspire (same as dsire hd). I took it apart to check the volume flex cable and the upper part of the cable had a slight rip. I went to this link and ordered a new one, popped it in and it worked fine.
http://www.repairsuniverse.com/htc-desir...
yours sounds like it could also be an issue with the physical button as well. I would open it up and take a look.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Maybe you just need to buy a new button piece: http://www.htcrepairparts.com/volume-key...
Puan 1
Yorum Ekle
If your HTC 7 trophy mobile phone volume keys not working then 1st check buttons,
if thy are ok but problem still then make Jumpers red line make jumper
HTC 7 Trophy Volume buttons not working
HTC 7 Trophy Volume buttons problem
HTC 7 Trophy Volume buttons problem solution
HTC 7 Trophy Volume key
http://repairphone24.blogspot.com/2014/1...http://repairphone24.blogspot.com/2014/1...
Puan 1
Yorum Ekle
Yanıtını ekle
Massimo Sgroi sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 3
Her zaman: 26,939
