Cracked screen and lines
Phone fell and screen is cracked also there lines appearing on the sideI
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Seems pretty evident you're looking for information about replacing your screen. There don't seem to be any written, iFixit-style step by step guides available for your particular model, but I did locate a pretty good YouTube video that will take you through the entire process.
Samsung Galaxy A24 Screen Replacement – Full Step-by-Step Repair Guide! - YouTube
It's a pretty straight-forward process, pretty much the same as most Android phones in that the recommended method of replacing the screen is to purchase it already mounted on the midframe, then just transfer the internals from the old phone to the new screen+frame assembly.
It is possible to replace just the screen without the midframe, but then you're dealing with glue and need an entirely different set of instructions. If you're not experienced at screen replacements, the screen+frame method is definitely the way to go, as there's much less possibility of anything going wrong.
As you work, take lots of pictures. Then, when you're done, you can use those to create your very own iFixit guide to Samsung Galaxy A24 Screen Replacement! It's easy, fun, and will have the appreciation of the repair community, especially those who come after you with the same problem.
Good luck, and be sure to let us know how it all turns out!
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 24
Her zaman: 154
