How do I back up my file
my computer is slow on my startup
Bu iyi bir soru mu?
If your computer is slow on startup and you’re worried about backing up files, you’ve got a few reliable options:
- External drive: Plug in a USB hard drive or flash drive and copy important folders (Documents, Pictures, Desktop).
- Cloud storage: Services like OneDrive, Google Drive, or Dropbox can automatically sync your files online.
Alternative method – using a hard drive enclosure
- Remove the hard drive: Power off your computer completely, open the case or laptop panel, and carefully disconnect the drive.
- Place it in an enclosure: Buy a compatible enclosure (2.5" for laptop drives, 3.5" for desktop drives), insert the drive, and secure it.
- Connect via USB: Plug the enclosure into another computer. The drive should appear like an external hard drive.
- Copy your files: Open the drive in File Explorer and drag your important folders to the new computer or another external drive.
Things to keep in mind
- If the drive is failing physically, copying may be slow or error‑prone. Specialized recovery software or professional services might be needed.
- If the drive is encrypted (e.g., BitLocker), you’ll need the password or recovery key.
- Handle the drive carefully to avoid damage.
This enclosure method is especially useful if your computer won’t boot properly or is too sluggish to work with.
Bu yanıt yardımcı oldu mu?
You can first back up your important files to an external drive so nothing gets lost, and also disable unnecessary startup apps to make your computer boot faster. If needed, you can try cleaning up the system a bit to improve performance before moving everything. And if anything gets deleted or goes missing, you can try Remo Recover Software to get those files back
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 9
Her zaman: 77
