Ana içeriğe geç
Sony Computer Entertainment tarafından üretilmiş bir oyun konsolu. PS4 olarak da bilinir. İlk olarak 20 Şubat 2013'de duyurulmuş ve 15 Kasım 2013'te satışa sunulmuştur.
Looking for a ps4 midframe part
I'm looking for a ps4 midframe part that looks like this
https://ibb.co/ksFFtFWj
Here's a website called fasttech where the part is in stock
https://fasttechstore.com/playstation-4-...
My question is are the parts exactly the same? I do have a CUH-1115A ps4 and the fasttech website seems to have the correct part in stock. From the pictures on fasttech.com, I really can't tell.
On fasttech.com, the back of the part, where the lan and hdmi plug in, it doesn't look slanted in the pictures.
I'm 99.9% sure that this is the correct part. The only reason I'd like to replace the part is because heat from the hardware has caused the plastic to break apart.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hi Justin,
Yes, as long as the model is exact the same, it should fit.
In your case, this is the case, so it should fit without any issues.
It's possible that they used a different model frame as reference photo.
You can always contact them to double check. If it does not fit, then return it and ask for a refund.
But again, most likely this one will fit without any issues.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
Justin sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 18
Her zaman: 81
