Ana içeriğe geç
250 GB HDD ve dahili Wi-Fi ile klasik Xbox 360'ın ince versiyonu. Onarım, karmaşık bir şekilde ayırma işlemi ve özel tamir aletleri gerektirir.
Random freezing, restarting by itself
My xbox is freezing during gameplay, mainly at the first loading screen I come across, rarely at the dashboard and I have to unplug the power cord to shut it off. Sometimes the wifi card isn't detected as well. I can play Rainbow Six Vegas 2 for 10 minutes before it abruptly shuts on and off by itself.
I've tried cleaning and repasting it, didn't work and I can confirm temps are low. I've also reinstalled the latest update.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hi!
Did you also tried to replace the HDD?
I would do that first and install the software again.
Guide: Xbox 360 S Sabit Disk Değişimi
If it's still failing, try to replace the Wifi card and see if that solves anything.
Guide: Xbox 360 S Wi-Fi Kartı Değişimi
I would try a new HDD first, you have some cheap ones at AliExpress and they do work fine.
Can you let us know how that goes?
Thanks!
Xbox 360 S Sabit Disk Görseli
Kılavuz
Zorluk:
Çok kolay
1 - 5 minutes
Xbox 360 S Wi-Fi Kartı Görseli
Kılavuz
Zorluk:
Orta
5 minutes
Bu yanıt yardımcı oldu mu?
Puan 1
4 Yorum:
I've tried removing the HDD before and it didn't do anything, I can run it without the wifi card and I still get the same issues so isn't that.
tarafından
If all the above didn’t worked, same for the HDD, then you most likely have motherboard issues. Most likely the internal memory on it.. I recommend to replace that. It won’t be easy as soldering is required. You can replace the motherboard but this will be expensive.
tarafından
@dan0 I have the Trinity model so was able to remove the 4gb internal memory, which fixed freezing during loading screens. The games now just freeze later on. The dashboard also wont respond to my input at times, but I'm able to open the smaller menu with the xbox button which does work.
tarafından
Okay! That’s a good thing!!
Please replace it for a new one and install it completely as new.
Does thet work?
Thanks!
tarafından
Yorum Ekle
Yanıtını ekle
MangosteenJuice sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 16
Her zaman: 160
