Not working USB on thinkpad e550
Hi. I have a Thinkpad E550 and USB port on the right side (next to DC in) is not working. I checked with USB load that it provides 5V, 1A. I tried Lenovo diagnostics in BIOS and it doesn't detect USB mass storage device. I disassembled the computer and checked for cold solder joints on the USB, they were OK (verified with multimeter). The USB port in question is on a small daughter board. Thinkpad e550 parts, part number: 00HT632
Resim
I replaced the flat flex cable and it didn't help. I'm wondering if I should replace the daughter board. Since it's expensive, before I order one I would like to ask if somebody has access to schematic of that daughter board and can verify if there's some circuitry on the board that can cause the USB data communication to fail.
On this machine is installed linux mint. Here is "lsusb -v" output
Thanks a lot!
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
3 Yorum:
Hi @vlado2
Did you check the status of the USB controllers in Device Manager > Universal Serial Bus controllers, to check if it showed that they were OK or not, you never said?
tarafından Paylaş
@jayeff I use linux mint. I added lsusb -v output to the original question. Please see the output for more details.
tarafından Paylaş
@vlado2
Sorry I can't help as I don't know about Linux.
tarafından Paylaş
Yorum Ekle
